Genesis clothing issues.
dinosaurmad87dinosaurmad87 Posts: 114
Hi everyone I've just bought some military camouflage clothing for a scene I want to do for my film. I've found the clothing in Daz perfectly fine, loaded up the genesis model but cannot seem to get the clothing to place on the model when I click on the 1 I want?
What am I doing wrong?
  • frank0314frank0314 Posts: 15,116
    Are you parenting the clothing to the figure?
    Are you sure you are finding the actual clothing and not a textures set for it.
  • dinosaurmad87dinosaurmad87 Posts: 114
    This is where I find them which I'm guessing should be correct?
    1024 x 492 - 102K
    edited April 2014
    Those are the materials for that clothing. Not the actual clothing. You load the clothing on then apply one of those textures
    Post edited by frank0314 on
    Oh right that makes sense then I placed them in Genesis, clothing, V3D which sends the folders into where I showed you in the screenshot. Where should I of saved them into for them to work or where do I go to find them?
    Do you have the V3 Shape for Genesis http://www.daz3d.com/v3-and-m3-shapes-for-genesis
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,809
    how did you get to that folder? by search?
    is it under people/genesis/clothing/materials
    if you go one step to the left in the menu the clothing icons should be there, I do not have that particular set but materials are usually a submenu of the clothing in question unless you only bought the textures.
    edited April 2014
    I bought these clothes for genesis http://www.daz3d.com/genesis-ultimate-military-basic and yes it is under that catagory
    Post edited by dinosaurmad87 on
    edited April 2014
    Nevermind I don't know where I got the V3 from. Here is the product list that tells you where the pack installs to http://docs.daz3d.com/doku.php/public/read_me/index/16056/start
    Ah you mentioned V3D and I mistook it as V3
    No worries and thanks for the link I'll take a look at it now :)
    You don't need that pack I linked for the outfit to work
  • Richard HaseltineRichard Haseltine Posts: 111,992
    The actual clothes are probably in the folder that's just partially visible at top-left of your screen shot.
    edited April 2014
    Do you mean this? If so then there is nothing there.
    381 x 515 - 39K
    393 x 514 - 38K
    Are you in DAZ Studio Format or Poser Format?
    You can also try re-importing your metadata
  • vwranglervwrangler Posts: 5,059
    edited April 2014
    Metadata shouldn't matter for items to be visible in the Content Library.
    I would suggest redownloading and reinstalling the clothing from the DAZ server. I have those items, and inside the Ultimate Military Basic folder, there should be four clothing items and a notice (see below -- ignore the extra pair of pants; I was trying a morph transfer experiment). If those items aren't there, then something may not have downloaded correctly.
    495 x 870 - 96K
    Post edited by vwrangler on
    edited April 2014
    Can you show me where you placed your ultimate military basic assets into when you unzipped the file so I can do the same for mine as that would help a great deal.
    I unzipped using DIM, which put the files into \content\People\Genesis\Clothing\V3D\Ultimate Military Basic -- I have a customized directory structure, so seeing anything above that wouldn't be helpful. What you see above is more or less where it put things.
    If you look inside the zipped file, you should see DUF and PNG files inside the \content\People\Genesis\Clothing\V3D\Ultimate Military Basic directory. If you don't see those, you need to redownload the file because something went wrong in the download.
    Ok chears for the help I'll take alook :)
    Right I've just checked the folder directory and from the look of you file route I have placed everything in the correct folder and I have seen the DUF and PNG files in there too.
    Here is what I see.
    1043 x 751 - 214K
    718 x 754 - 184K
    729 x 738 - 212K
    723 x 754 - 144K
    what happens if you drag the duf files directly from your window into Daz?
    I actually do that sometimes myself!
    Ok I'll give that ago and see what happens
