Trouble removing old, saved scenes from Saved Files
nomad-ads_8ecd56922e
Okay, I have a whole bunch of old, saved out scenes I decided I no longer wanted cluttering up my Smart Content > Saved Files pane. I moved them all out of the actual directory for safekeeping, and now all of those show a thumbnail image with a picture frame with a ! in a triangle. I then went to Content Library > Categories > Default > Saved Files > Scene, and from there, I right clicked one or more of these broken thumbnails, and selected either Remove Orphaned Reference..., or Remove Reference..., I then get a dialog asking Are you sure you want to remove the orphaned reference? I select Yes... but then a moment later, I scroll down to look at the scene thumbnails, and the scene or scenes I just told it to remove are still there!
What am I doing wrong, did they break this function? 0O
I have something like 200 of these in there. It is becoming harder and harder to keep track of what old scenes I still need to work on, because they're getting lost in the forest of completed works. :O
Try removing orphaned references from Content Library -> Products -> L -> LOCAL USER.
I don't see any of my own, saved out scenes in there, just a bunch of other people's product thumbnails.
Hang on, I think I figured out what's going on. I didn't notice that when I went to Content Library > Categories > Default > Saved Files > Scene at the top of the icons pane, it was saying 1-264 out of 500-something. I thought I had scrolled all the way to the bottom of the entire set of thumbnails.... So, I removed 26 or something of them, and after it removed those, there were still 26 (other) ones, since there was a big block of possible 100 of them, and I was only seeing the topmost 26 of those at a time, so I thought it hadn't removed ANY of them.
So, I clicked the <- [1] -> thingy to move to <- [2] -> and selected some of the broken thumbnails, and it DID remove them.
Looks like I have the mystery solved. :D
