(Solved) I need help correcting an imported FBX model
tkdroberttkdrobert Posts: 3,639
edited April 2020 in The Commons
I don't know if I can explain this right, but I'll try.  I imported an FBX model into Daz and the X,Y,Z controls are all off.  For example the directional arrows are way to the right.  If I do any rotation the object doesn't stay in place.  Instead, it roHow do I realign them.  Placing the object in a scene is really hard.
Post edited by tkdrobert on
  • jjmainorjjmainor Posts: 500
    I usually send the object to Hexagon, center it in the world, then send it back to DS. Otherwise, you could use the joint editor to adjust the pivot point manually.
  • Griffin AvidGriffin Avid Posts: 3,890
    Or you can create a null and move that to where you want the pivot point to be and then parent the FBX model to the null and use the null to move things around.
    I also uncheck the "selection check" so I don't keep trying to grab the model and move it directly.
  • tkdroberttkdrobert Posts: 3,639
    So here was my solution.  I imported the fbx into Poser.  I then exported it out as an OBJ.  When I imported the OBJ into Daz, all was good.
