Vintage Furniture Install loop
EZ3DTVEZ3DTV Posts: 1,652
A couple days ago i bought, "vintage furniture" and now it is in an install loop.
Each time I refresh install manger it shows up and I install it and then refresh and there it is again.
Could someone look into why this is happening?
I am quite sure it got installed but something is still wrong.
Thanks in advance.
Post edited by EZ3DTV on
  • westechiewestechie Posts: 17
    1) Reboot your computer.
    2) Access DAZ Install Manager.
    3) Make sure the third pane labelled as Installed is selected.
    4) Put a check mark on Products, so that every thing is selected.
    5) Right click on Products and select Re-Import Metadata -> All Selected.
    6) After that, you may check your Asset.  If it still fails, then repeat steps 1) through 4), except this time right click on Products and select Re-Install Package(s) -> All Selected.
    That should be enough to fix your issue.
  • dawnbladedawnblade Posts: 1,723
    Happened to me too. But when I read the description it appears there are 2 downloads, and this one is meant for us to use in Photoshop to make our own mats. Pretty generous of the  PA! The regular mats are installed,  so you can ignore this one in DIM.
  • EZ3DTVEZ3DTV Posts: 1,652
    Thanks for the help, lots of good tips! :)
    Disregard my initial reply. There should be a new update in DIM that will remove that extra "Vintage Furniture." It did for me.
