IK Disabled. Limbs still jump.
I have this problem with a lot of figures, but using the Dog 8 as an example. Whenever I move the figure with either the sliders or arrows, the limbs move slightly out of their set pose. I turn off IK and Pins and the limbs still move. Annoying when trying to fine tune a pose. Is there a way to disable this quirk?
Post edited by cathan01_wwg1wga on
  • SimonJMSimonJM Posts: 6,102
    I don't disble IK when that hapens, I go to scene tab, expand the root node and dleet teh (usually) 4 IK nodes there.
  • cathan01_wwg1wgacathan01_wwg1wga Posts: 381
    edited April 2020
    Works perfectly after deleting those IK nodes. Thank you, SimonJM.
    Glad it worked for you!
    I also found that if you had the Universal tool selected and just moved on one axis (usng the arrow tip) all was fine, but if you tried to go in two directions (say X and Z) using the 'triangle' then it would glitch.
