HELP BUILDING A NEW PC
Budget Range: $1,200-1,700
PC usage: rendering in DAZ3D studio iray, general use, graphic design (Photoshop, Illustrator), and watching movies (digital and dvd)
Monitor: using my current monitor (Asus 23’’ widescreen LED monitor)
Keyboard and Mouse: using my current keyboard and mouse
Operating System for new PC: Windows 10 Pro
Hi, I need help building a PC that I can render complex 3d scenes in DAZ Studio 4.12 that won’t slow down my PC, the PC will also be used for general use and Photoshop. I don’t have a problem waiting for complex scenes to render in 1-2 hours as long as I can use the PC for other things while DAZ Studio is rendering in the background. Thank you
MY OLD PC SPECS 2014: (Please let me know if there is any parts of my old PC that can be used for my new build.)
CPU: Intel Core i7-4770K Haswell Quad-Core 3.5 GHz LGA 1150 84W
Motherboard: GIGABYTE GA-Z87-DS3H LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
GPU: MSI GeForce GTX 650 Ti DirectX 11 N650TI-1GD5/V1 1GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
RAM: Ballistix Sport 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
HDD: WD Black 1TB Performance Desktop Hard Disk Drive
Case: Corsair Carbide Series 200R Black Steel / Plastic Compact ATX Mid Tower Case
PSU: SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
Monitor: Asus 23’’ widescreen LED monitor
OS: Windows 7 Professional SP1 64-bit
DVD Drive: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
3 Recommended upgrades from me to you.
1) Your mother board does not support ECC RAM. You might consider a mother board upgrade in the future that supports non-buffered ECC to reach 32 GB of RAM. You don't need this, but it's super nice. It also can cause havoc on your main system if you mess up the install. How ever, your CPU certainly supports non-buffered ECC, so you can keep your Intel i7-4770K for the future. It's a very nice CPU for what it allows.
2) You can get Windows 8.1 Pro or Windows 10 Pro for cheap if you want. Make sure to look for an OEM version off of Ebay. DOWNLOAD THE OS IMAGE FROM MICROSOFT'S WEB SITE. You should copy your OS install image onto a cheap 32 GB USB 3.0 drive. You can get those for $5 easily. Other wise, good luck on where you buy. I suggest sticking to a vendor who has 98% reputation or higher and also 1,000 Reviews or more. You can see that off what ever product page. Win 8.1 Pro or Win 10 Pro might cost you $25 for an OEM license key. You absolutely need this to render correctly. Also, make sure your stuff is 64-bit.
3) You need better graphics hardware. At minimum, you should shop for a NVidia GTX 970. You can probably find this moderately cheap, and it provides good gaming experiences if you want. If you prefer some thing more fancy, then shoot for a higher number and some thing with a Ti on the end of it. For instance, an NVidia GTX 1080 Ti still remains top quality. I suggest NOT going for an Nvidia RTX series graphics card. Your current mother board will not pump out the maximum you want from it.
would like to know is this a good build:
PCPartPicker Part List: https://pcpartpicker.com/list/HPv3Mc
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor
CPU Cooler: NZXT Kraken X53 73.11 CFM Liquid CPU Cooler
Memory: Corsair Vengeance LPX 32 GB (4 x 8 GB) DDR4-3200 Memory
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive
Video Card: NVIDIA GeForce RTX 2070 SUPER 8 GB Video Card
Case: Deepcool MATREXX 50 ADD-RGB 4F ATX Mid Tower Case
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Home OEM 64-bit
Motherboard: Wondering if any of these Motherboards work for this build
Asus PRIME X570-P ATX AM4 Motherboard https://pcpartpicker.com/product/McfFf7/asus-prime-x570-p-atx-am4-motherboard-prime-x570-p
Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard https://pcpartpicker.com/product/dmGnTW/asus-tuf-gaming-x570-plus-wi-fi-atx-am4-motherboard-tuf-gaming-x570-plus-wi-fi
MSI MPG X570 GAMING PLUS ATX AM4 Motherboard https://pcpartpicker.com/product/q4Dkcf/msi-mpg-x570-gaming-plus-atx-am4-motherboard-mpg-x570-gaming-plus
MSI B450 Gaming Plus MAX ATX AM4 Motherboard https://pcpartpicker.com/product/BHBhP6/msi-b450-gaming-plus-max-atx-am4-motherboard-b450-gaming-plus-max
