[BUG?] Invisible Elements leaves traces on clothing
Hello,
As the title says, I've been experiencing issues with the DAZ software where a node would be invisible but would leave traces by affecting clothes collision. As attached, you can see what I'm talking about. The figure being used is Genesis 8 Male, the swimwear is for Genesis 8 Male and not d-force, and the object invisible is NSFW. I don't know how to fix this issue without having to delete the object from the scene. Your help will be greatly appreciated! Thanks!
https://ibb.co/KrDyrCd
https://ibb.co/2nT51Gz ;
Just in case the images decide not to load.
  • It's because the genitials are a geograft, so they leave a hole in the mesh if just made invisible. You'd be better served using a smoothing modifier on the shorts or a dformer to pull the shorts out to cover the genitals, instead of just hiding them.
  • kaotkblisskaotkbliss Posts: 2,918
    if you're just hiding the Gs, you could also simply leave them not hidden and scale them down to like 1%
    That would leave them inside the clothing without leaving a hole in the figure
