hair is transparent in png
I want to use png renders so I can create layers but the hair is transparent. Is there any way around this? The background shows through the layers.
732 x 411 - 349K
  • Richard HaseltineRichard Haseltine Posts: 111,363
    You could try using a level adjustment on the alpha channel.
  • How do you do that in an OpenGL render?
  • jjmainorjjmainor Posts: 500
    If you're using opengl, try adding a spotlight. If you don't want the extra light, set the intensity to .05 or .01. I tend to have a problem with hair when I render with opengl unless there is a spotlight in the scene.
