Suggestion
AngelAngel Posts: 1,204
edited April 2014 in The Commons
Just a suggestion if its possible. On the next update it would be very nice if we can arrangement the morphs based on date applied. Sometimes I want to revert back to the way I had an actor, but I cant remember the last 30 or so morphs I used. I know you can use the undo feature but that don't work after you reload a scene and it only goes back 15 undo's or so. I'm fairly confident that I'm not the only one who would like to be able to arrange the morphs based on date applied. I actually find it very weird that there is no such option considering the depth and complexity of this program and the sensitivity of morphs.
Post edited by Angel on
  • DZ_jaredDZ_jared Posts: 1,316
    You can use the "Currently Used" group in the Shaping Pane to get a list of all Morphs that are not at their default load state. This list is alphabetical, not chronological though.
    Still, unless you have a ton of morphs dialed up, it should be a helpful feature for what you want to do.
    Remember you can always submit a feature request through our help center: helpdaz.zendesk.com submitting a feature request there means that the developers are much more likely to see it.
    Keep in mind that just because you submit a feature request does not mean that it will be included in future versions of DAZ Studio.
  • AngelAngel Posts: 1,204
    Currently used does not help me any when I don't know which one it was I used last.
    Try incremental saves with unique labels that you recognize.
    Wouldn't a scene file with all that extra data included become rather large?
    There also 'Memorize' and 'Restore' in the Parameters tab options.
    Does memorize have multiple levels or does it just memorize the current set of morphs? Same question in regards to restore. The OP wants a reference stack of all the morphs applied from the date the file was created to the current date. Listed by morph and date/time. Even if it the scene is saved, the current active session ended and the application closed.
