How to get skirt fit nicely between the legs (Solved)
stevejintastevejinta Posts: 27
edited April 2020 in The Commons
Hello guys,
As you can see the gap on her right leg... Any idea on how to get it fit and tight perfectly?
Regard,
Steve
636 x 536 - 27K
Post edited by stevejinta on
  • Richard HaseltineRichard Haseltine Posts: 111,642
    dForce, if the skirt works with that, might help.
  • Adding a smoothing modifier?
  • novastridernovastrider Posts: 208
    edited April 2020
    Smoothing, interactive update + collision iterations, blowing up the size of the limb inside the items parameters, getting Sickle Yields autofit corrections for dresses: pick one of these.
    Post edited by novastrider on
  • Got it! By EDIT > OBJECT [You may want to select the particular object before proceed] > GEOMETRY > ADDING SMOOTHING MODIFIER.
    Thank you TheMysteryIsThePoint and novastrider.
    Richard Haseltine for the dForce which you mentioned, I have checked it out, found it quite heavy for now. Thank you, by the way.
    Regard,
    Steve
    259 x 227 - 12K
