Rendering stuck in an infinite loop
For some reason when I try to render certain scenes the renderer gets stuck at "rendering..." this is usually took only a few seconds but now it takes forever and nothing happens. The scene renders properly in the viewport using the iray renderer. Nothing happens if I press cancel either. The only way to stop daz studio is to kill the task in task manager.
  • SimonJMSimonJM Posts: 6,102
    Maybe a silly question, but what is in the scene?  I have seen something similar with a G3 figure with SubD > 3
  • It's pretty annoying that this issue hasn't been fixed, I've narrowed it down to the SubD as well. With even one figure with a viewport SubD higher than 1 and a Render SubD higher than 2 it will stick at "Rendering", and this is with a HDRI for the environment. I have a GTX 1080 ti and a Ryzen 7 and 32 gb of memory so I doubt it's a hardware issue. I guess HD figures are to much to ask for, guess I won't waste any more money on G 8.1 then will I.
    If you have found steps to reproduce the issue please send them to Daz - once they have a clear understanding of the issue they can look into fixing it.
