How to view two properties at once?
mostlyhumanmostlyhuman Posts: 94
edited April 2020 in Daz Studio Discussion
I want to adjust a morph while looking at its affect on a specific joint's transform values, if I pull up the joint in the parameters area but then click the Parent node to apply the morph, the Parameters window automatically changes to the Parent object display.  How can I lock the parameters window so it doesnt change when I select a different node? Or whichever other solution would allow me to achieve the same thing,  Thank you for any help!
Post edited by mostlyhuman on
  • RobinsonRobinson Posts: 751
    edited April 2020
    You can "favourite" the two properties (heart icon) then click "Favourites" in the parameters pane, whilst having the root node selected it will show the favourites.
    Post edited by Robinson on
  • SimonJMSimonJM Posts: 6,108
    Ctrl (Cmd on a MAC I believe)-click on the 2nd bone/node to select both then you will see both items in Parameters and be able to navigate each set of properties 'at will'
  • Richard HaseltineRichard Haseltine Posts: 112,009
    If you are wanting to see the joint rotations you may need to turn off Consolidate Proeprties in the Parameters pane option menu (the line button in the tp corner, or right-click the tab - in the Public Build it's now in a sub-menu)
