Is there a shader to change Iray to 3DL, like irayuber?
I'm experimenting with new render ideas and think I might have an easier time converting characters and clothes to 3DL. Problem is I made them all with iray materials and shaders.
For the most part, when I apply iray uber to a 3DL surface, it transfers over and gives me iray options. Is there a 3dl equivalent? I don't want to use a preset 3DL because that may override any image maps I have on the surface in iray.
There's no automatic conversion from Iray to 3DL in DS. You can try applying the ubersurface base shader, but I'm not sure how well it would work.
There's a free conversion script which can give you a starting point here: https://www.daz3d.com/forums/discussion/139326/irayto3delight-conversion-script/p1
You might also be interested in RSSY Iray to 3DL Converter: https://www.daz3d.com/rssy-iray-to-3delight-converter-and-merchant-resource
Thank you!
I've discovered that a shader from this https://www.daz3d.com/advanced-ambient-light does exactly what I'm after.
