DSON importer for Poser
grpruettgrpruett Posts: 255
Today, I just installed Poser 10 and I can't install DSON Importer for Poser. The importer can't find the required path.
What is the required path for the importer?
  • frank0314frank0314 Posts: 15,094
    How are you trying to install it. Manually or with DIM
  • grpruettgrpruett Posts: 255
    I'm using DIM.
    GO to the applications tab and click the + and add your path to your poser main directory
    I created a path to the my poser directory as follows.
    c:/Program Files (x86)/Smith Micro/Poser 10.
    I labeled the path Poser and I have it selected.
    I added Poser 10 to the application tab as well with the same path.
    I'm still getting "Install Manager can't find the required path."
    Is there something else I should be doing?
    Okay, I think I know what I was doing wrong. I was trying to install 64 bit importer when I needed to install 32 bit.
    Yes that would be your issue
