Skin looks "dirty" in the renders
comixfanacomixfana Posts: 278
edited April 2020 in The Commons
It seems to be more prevalent rendering naked bodies...the scene looks perfect before rendering, but the resulting image looks like the character rolled in the dirt before getting intimate with his/her lover (thus I can't post an example of what I'm talking about...) hopefully I've explained the issue properly and there's a way to fix it?
After giving it another look, it seems to be a problem on the Genesis 8 Female figure, I'm not seeing it on Victoria 8 or Daciana, and I'm not noticing it on the male figures either.
Thanks
Post edited by comixfana on
  • QuasarQuasar Posts: 700
    Can you create a scene with the character wearing a bikini and recreate the same problem? That would help to see what you mean. All of the generation 8 figures, including Victoria 8, are based of the Genesis 8 Female. It sounds like it could be a texture issue.
  • comixfanacomixfana Posts: 278
    Here goes, looks like black swirlies on the arms and legs
    1023 x 849 - 407K
  • Could they be LIE blood splatters? Have you used a product like that at any point?
    Might be worth looking in the lie editor for a rogue layer in the leg and arm surface material diffuse image. Or any other image layer. Or is there a geoshell with the stuff as a transparency & texture?
  • Do you have a geoshell or another figure that is transparent that is touching the geometry of the figure? This looks like what happens when the transparent part of a headcap of an OOT hair is taking up the same physical space as the figure geometry.
  • GreeboGreebo Posts: 166
    This is what I thought too.
    Try an area render of just the arm so we can see the effect close up?
    Nope! :)
    I'll look, but while I've used LIE tats on a different character, never on this one, and never blood splatters
    You might have something there, the Breastacular invisible collision gloves and stockings!  Let me doiuble check that!
    We have a winner!  Looks like the "invisible collision gloves" weren't so invisible after all!  Same image (with a closeup) with the collision gloves removed! Thanks Hanabi!
    1023 x 849 - 416K
  • plasma_ringplasma_ring Posts: 1,027
    I'm usually able to fix this by turning off smoothing, or by adjusting the fit/offset of the item until no part of it is clipping with the character.
