[SOLVED] DAZ Studio 4.12 public build MAC install failed
tgracetgrace Posts: 48
I'm trying to install 4.12 because I'm not longer able to open my .duf files on Catalina. But, everytime I try installing through the install manager, it fails.  Here is the log:
+++++++++++++++ Install Manager 1.4.0.17 starting +++++++++++++++++
OS bits: 64
Platform bits: 64
Qt Version: 4.8.7
Locale: en_US
Running on Macintosh OS 10.15 Catalina
Current DateTime:
    Loc: Mon Apr 13 23:48:23 2020
    UTC: Tue Apr 14 06:48:23 2020
Application Data:
    Location = /Volumes/2TB-SSD/tg/Library/Application Support/DAZ 3D/InstallManager
    Disk Total: 1.8 TB (2000054960128)
    Disk Avail: 1.3 TB (1462158446592)
Reading dzInstall.ini
Current Account: Account
Current Download Path:
    Location = /Volumes/LaCie/DAZ 3D/InstallManager/Downloads
    Disk Total: 5.4 TB (6000497983488)
    Disk Avail: 1.2 TB (1369151406080)
Current Content Install Path:
    Location = /Volumes/LaCie/My DAZ 3D Library
Current 64-bit Software Install Path:
    Location = /Applications
    Disk Total: 233.4 GB (250685575168)
    Disk Avail: 153.0 GB (164311482368)
Current 32-bit Software Install Path:
Manifest directory set to: /Volumes/LaCie/DAZ 3D/InstallManager/ManifestFiles
Starting CMS...
Connected to CMS: PostgreSQL 9.3.4 on x86_64-apple-darwin, compiled by i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.9.00), 64-bit
Installed Packages: 343 : 37.0 GB
Remote Tags Missing: 42071-3 : Genesis 8 Starter Essentials Mimic
Remote Tags Missing: 9087-2 : Old West Sheriffs Office Ps
Remote Tags Missing: 5725-1 : Hallowed Eve Ps
Remote Tags Missing: 2080-1 : Millennium Environment Ps
Remote Products: 214
Remote Packages: 407
Installing: 12000-4 : DAZ Studio 4.12 (Mac 64-bit) Public Build +BETA+
Install Failed: DAZ Studio 4.12 (Mac 64-bit) Public Build +BETA+
Install Queue Finished: 0 min 10.6 sec
User Data Refresh: Elapsed Time 0 sec 173 msec
Saving Account Settings: Account
Install Queue Finished: 0 min 0.8 sec
Install Queue Finished: 0 min 0.9 sec
Installing: 16598-4 : GoZ for DAZ Studio 4.12+ (Mac 64-bit) Public Build +Beta+
Application Not Found: DAZ Studio 4.x Public Build (64-bit)
Requirement Failed: IM00016598-04_GoZforDAZStudio412Mac64bitPublicBuild.zip : moving on
Install Queue Finished: 0 min 0.0 sec
WARNING: QObject::connect: Cannot queue arguments of type 'QAbstractSocket::SocketState'
(Make sure 'QAbstractSocket::SocketState' is registered using qRegisterMetaType().)
--------------- Install Manager exited ------------------
Post edited by tgrace on
  • TotteTotte Posts: 15,242
    Are you running DIM from an account that "can admin the computer", which means it has the rights to require an authentication dialog to ask you for privilegies when installing?
  • tgracetgrace Posts: 48
    Yes. I do get a pop up message that requires a password at the very beginning of the process and then after I enter it and the process resumes, it fails. See screen shot.
    2086 x 1912 - 394K
    Hmm, I know they did some 10.15 fixes in DIM, the problem is Apple adds new security things to macOS all the time.
    Which version of 10.15 are you running?
    10.15.4
    I had the same issue in the previous version. Is it possible to manually install this?
    I think manual install won't work either as the same issues with protected folders will happen again. Apple has been making it very hard for unwanted softwares to be installed, which makes it hard to install wanted softwares too.
    SUCCESS!
    I finally figured it out -- With Mac's Catalina, there is something called SIP - System Integrity Protection. You can disable it by booting up into Recovery Mode, opening Terminal and entering: csrutil disable then restarting. I was then able to install the public build and open my old .duf files. To enable SIP again - boot into Recovery and in Terminal type: csrutil enable... etc.
    Good find, then it sounds like DIM has issues with the entitlement settings that is used by OS X to allow/disallow actions the program does depending on the signed entitlements.
