FBX morph memory hog in Cinema4D problem
Hello, :vampire:
My workflow recently consisted of export character with bone and morph from DAZ (as FBX), and import it into Cinema4D (R15).
The rig and morph works perfectly in Cinema4D. I can pose character any way I want.
:sick: But somehow, the pose morph function in C4D consumes tons of RAM in a blink of an eye. Every change to the morph parameter, even the slightest, eat hundreds megabytes of RAM. I have 12gb of RAM, and I have to quit C4D 5 minutes later after adjusting some face morph, because Windows told me that I ran out of memory, the first time in my life actually.
I also test it with Maya, both the rig and morph works fine, without memory hog!
My guess is this might be C4D problem rather than DAZ, but before I give up the morph function in C4D completely, do anyone know any workaround or any tips for me?
Big thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,996
    How many morphs are you including in the FBX file? have you tried being more selective, if you aren't initially? Presumably you could always export a morph as an OBJ and then load that into C4D and transfer it to the imported figure (I assume there's a way to do that in C4D, I'm not familiar with it) if you later decided you needed.
  • edited December 1969
    Hi Richard,
    That's good point you mention, because I indeed exported the whole head.CTRL morph (or even worse, all of CTRL)
    I then try selectively choose just only 3 and the memory consumption is a lot better and acceptable! Guess I have to live with less morph.
    Thank you for the help! :)
