Can you have LAMH installed as well as Garibaldi Express Hair System?
WilmapWilmap Posts: 2,917
My friend is interested in getting LAMH after seing it on my PC, but she already has Garibaldi Express Hair System installed and doesn't really wan't to remove it.
  • KeryaKerya Posts: 10,943
    Yes.
    The installation of both is no problem.
    I didn't try to use both in the same scene (I can imagine it would lead to trouble), but I have both installed.
  • WilmapWilmap Posts: 2,917
    Thanks Kerya, I will pass on that information.
  • GoneGone Posts: 833
    Having both installed is not a problem but, as Kerya pointed out, you can not use both in the same scene. You can use LAMH export to save generated hair as a fibermesh type object and use that in a scene with Garibaldi since the LAMH fibermesh style hair will now be treated like any other object.
    There is a further caveat to be aware of. Once a LAMH asset has been used, LAMH does NOT shut down when you clear the scene and start a new scene. This means that if you try to use Garibaldi assets after using LAMH it will not work properly because LAMH is still active and fighting with Garibaldi.
    The only way you will be able to use Garibaldi will be to shut down DS to turn off LAMH and then restart DS so you can use Garibaldi without interference.
    Garibaldi does close when you clear the scene so it will not interfere with LAMH in a new scene.
    that means i can't use Catworld HD people with hairy garibaldi people i make, in the same scene?
    dblfacepalm
  • JabbaJabba Posts: 1,466
    dblfacepalm
    not at the same time... you could do spot renders and combine together in post.
    dblfacepalm
    animation woes. :)
