NVIDIA Iray Viewport Rendering - Not working
Occasionally i will create a large scene in which the Iray viewport preview will stop working after a while.  Even after i hide most assets, restart daz, etc.
As i rotate the camera, i can see the iray preview start to render as a pixelated image. However as soon as i stop rotating the camera, it goes back to a smooth-shaded view.
The Iray preview will have worked fine up until that point.
Is there way to fix this?
  • Richard HaseltineRichard Haseltine Posts: 111,408
    Even if the GPU drops out it should use the CPU, unless - in the current Public Build - you have prohibited CPU Fall back.
  • lilweeplilweep Posts: 2,873
    when i deleted my instances and converted them to normal nodes, it went back to normal.
