How to change size of Morningstar Wings
I'm trying to apply the Morningstar Wings to a character, but they're huge. Is there any way to shrink them down to a size similar to what's seen in the promo images for Z Angel & Devil?
  • kenshaw011267kenshaw011267 Posts: 3,805
    Try changing the scale?
  • Try changing the scale?
    I can't see a "Scale" option anywhere in Parameters.
  • scorpioscorpio Posts: 8,533
    Have you got show hidden properties ticked.
    I would also suggust not fitting them to the figure but parent them to the upper chest.
    FWIW, I think most wing sets are supposed to be parented, not fit-to. After all, you can put them on any figure, DAZ or non-DAZ, animal, fantasy critter, or whatever. Fit-to isn't flexible enough to go with everything, but with parenting, it doesn't matter.
  • MadaMada Posts: 2,065
    To scale them you have to click on each body part individually and adjust the scale dial - 4 bodyparts per wing :) Because its a conforming item you can't scale with the body dial.
    Scaling that way instead of parenting it keeps it in the right position on the body, if you scale using parenting you have to adjust the wings manually because it drops down lower.
    Thanks so much for this tip!
