Question about Stonemasons Sci-Fi Bedroom
ruekakaruekaka Posts: 348
It looks fantastic, but I have a question about the details in the scene.
Are they fix or can the be removed/changed (e.g. the pillows and the blanket looks the same for me in all pictures)?
Thanks in advance for any information.
  • FeralQuokkaFeralQuokka Posts: 81
    From what I've seen playing with it, the pillows plus most items on the shelf can be hidden/removed or moved around, and the blanket has several morphs to flatten sheets, puff it up to simulate someone sleeping, etc... There is also a cupboard door that opens and so does the main window.
    For my purposes, it's a great set and versatile enough to be used in multiple scenarios. Hope that helps.
  • ruekakaruekaka Posts: 348
    Thanks for your reply.
    So no chance to resist anymore ;-)
    It's a Stonemason... he will assimilate us all.... and our wallets. ;)
    But, yep, it's a very good set IMO. Depending on render settings it can take a little while to render, but well worth the wait for the output.
    That's true!
  • SupercopeSupercope Posts: 128
    The photos on the wall and the books on the shelf can all be hidden. The pistol at the end of the bed can be moved as well. If you need a door, you might be able to fit in parts from either Modular Sci-Fi Kit 01 or Sci-Fi Corridor 2013 if you own them. I played around with them, but didn't find anything satisfactory yet.
  • TotteTotte Posts: 15,278
    Stonemason - resistance is futile - we will be assimilated
  • DekeDeke Posts: 1,636
    I'm also having problems installing this. I'm using Daz and Install Managers, yet when I click the icon in Smart Content - Environments, I get a long list of missing files. I know there are in the Daz Content- Data folder, but for some reason they are not cooperating.
    Can be that smart content is borked, I just haven't had time to play with it so I haven't checked it out.
    Borked? that's a new term for this newbie. I have found the "scene" file in the content library, but even then when I try to load it into the scene I get that long list of missing or unlinked data files. And there doesn't seem to be a "relink file" option anywhere.
  • ZarquenZarquen Posts: 23
    wow!!
    This set is impressive, as all Stonemason's items.
    Any ideas of any other sets to fill the room? (some kind of side-table, etc...)
    thanks
