Morphs not wanting to work.
Got the a bunch of M4 and V4 morphs from the recent freebie bundle....put them in.....nothing works.  Can't find them anywhere on the figures.
What gives?
I sooooo miss the old exe's one could use.....THOSE worked.
  • BejaymacBejaymac Posts: 2,003
    Runtime > Libraries > !DAZ
    In there you will find files that start with DzCreateExPFiles, .bat for PC and .command for mac, not sure about the mac but on PC double click the .bat files to start the system that builds the EXP morph channels.
    After you have ran all of them your V4/M4 CR2 should now have a whole pile of empty channels, unless you have overwritten the original CR2 which will have broken the EXP system.
  • Richard HaseltineRichard Haseltine Posts: 111,408
    If you install the PowerLoader files you will also get a dialogue on loading the figure which will let you choose which morphs to load, by product or individually, without needing to run the dzCreateExPFiles-m4/DzCreateExPFiles-v4 files.
    Installing with DIM should have ran the bats.  DAZ Generation 4 figures cannot be installed using Connect.
