A transparent ceiling that does not transmit light? (3delight)
roezakaroezaka Posts: 64
I need to render the room from a high position of the camera, for this I remove the ceiling, but then the light passes through it and the lighting becomes not natural. Can this be fixed somehow?
Post edited by roezaka on
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Create>New IIray Section Plane Node, position it so it is just below the ceiling, and in its Parameters turn on Clip Lights.
    I believe there is a way using section planes :
    https://blog.irayrender.com/post/48117954581/section-planes
  • roezakaroezaka Posts: 64
    https://imgur.com/mcEUW7a
    With ceiling
    https://imgur.com/TdbCz4t
    Without
    https://imgur.com/zOh36yO
    https://imgur.com/UsTMkB4
      With section Plane
    Where am I wrong?
    I'm a little confused now - I thought you wanted to render the scene from high up, but you are rendering it from in front - or is that just for illustration purposes? I can't really tell where the plane is, it would be better to upload the imges to your post then we could view them full size by clicking them.
    edited April 2020
    This is for illustration.
    But the ceiling is still off - the Section Plane will hide (in the render) things that are visible, it won't do anything to things that are hidden. Show the ceiling, place the plane just under it, turn clip lights on, and render.
    Thanks! I understood how it works. But I was hoping that this would also work on 3delight. But no :( Is there a way to do something like this on 3delight?
    edited April 2020
    It's very simple;)
    Select the ceiling in the scene tab and in the surface editor, apply the OmUberSurface shader, turn on Fantom. Now the ceiling will cast shadows but be invisible to the camera. Simple demonstration, a spotlight, a ground plane, a second plane (ceiling) just under the spotlight, with Fantom active:
    1266 x 679 - 164K
    1280 x 720 - 130K
    Post edited by Sven Dullah on
    Not pre-set, it is possible to use Shader Mixer with a RayTest brick (I can't recall the exact name, last time I did this was in DS 3, or possibly even DS 2) to tell   eye rays (coming from the camera) from light or reflection rays and use that to set the opacity - that way you can make the surfaces transparent when looked through directly but opaque to lights and in reflections.
