Black Rings around the eyes
Hello! I've been toying around in Daz for about a month and suddenly these rings showed up around g8f Victoria's eyes. I added a distantlight, if that changes anything, but when I removed it and put things back to normal this is still what I got! Any idea what's happening?
309 x 192 - 25K
172 x 196 - 21K
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Is the figure still in the middle of the world, or have you moved it?
  • jerekickjerekick Posts: 4
    I have moved it, but I have made a small series of 25 pictures and only recently has this problem occurred.
  • I had this problem last night, G8f figure. And it has happened before. No idea what causes it or how to fix. I gave up, will fix in post.
  • Instancing optimisation is probably on memory, needs setting to auto or speed and even then the figures need to be withing 2000 units of the center.
    What your seeing is typical of being too far from the center in the Z axis.
    Thanks all for the help. Sounds like having figures away from the center is a problem in Daz studio. If you ask me that's a pretty big bug.
  • felisfelis Posts: 6,549
    Well, to avoid misunderstanding. It is Iray that is the problem, and that is developed by Nvidia - Daz Studio has just integrated it.
  • jpetersen1jpetersen1 Posts: 148
    The problem has been mentioned on several threads. I've had it happen with three different characters. I suspect the sclera and eye moisture geometries are interfering with each other in some way.
    One poster suggested increasing the eye moisture setting. I tried this, it didn't solve the problem, there were still some very small tar-like splots, but it helped quite a bit.
