PFE missing
RoygeeRoygee Posts: 2,247
Whatever happened to the PFE in Studio 4.6.2.118? It is not among the scripts and when I try to install from a download, I get an error ...S{installdir_content) resolved to an emplty value.
The installer also doesn't give an installation path option.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,633
    download the zip and unzip
    you can drag and drop the script into studio, I do for saving pz2 animations carrara 8.1 and Poser7
  • KeryaKerya Posts: 10,943
    PFE never was included in Dazstudio - it is a separate "purchase" for $0.00
    http://www.daz3d.com/poser-format-exporter-pfe
    If you use DIM, search for Poser Format Exporter, if you prefer to download from the store:
    http://www.daz3d.com/downloader/customer/files/#prod_8040
  • RoygeeRoygee Posts: 2,247
    Thanks for the replies:)
    Yes, I knew it wasn't included, but I've had it since forever and expected it would have been included when i did a total re-install of everything Daz using DIM.
    Anyhow, wasn't able to locate it through DIM, but found it in my product library. Doesn't seem to be DIM ready?
    First downloaded the zip, and unzipped - it went into an endless loop at 99% extracted - showed 7 errors Then downloaded the .exe, which didn't know where to install - did give me an option though, so was finally able to get it working!
    Wendy - you being so experimental:) Do you know how to convert the pz2 import to an NLA clip in Carrara? it makes the clip OK, but doesn't delete the pz2 from the timeline. When I manually delete and load the clip, it doesn't work.
    Cheers:)
    I have no idea as it deletes the keyframes for me.
    are all the bones and morph groups ticked in the clip heirarchy when you save it?
    edited April 2014
    Thanks, Wendy:)
    When I say it doesn't delete the keyframes, well, what I get on import is not the black triangular keyframes, but a coloured line with marks for every frame, which stretches to eternity. If I ask to load clip data, I get the normal keyframes, packed solidly, and the timeline freezes up - can't even scrub it. Won't make an NLA clip from that.
    Yes, the NLA I make has all the boxes ticked and everything done the way I normally make an NLA.
    OK - the imported pz2 makes it's own clip, which, if I bring it into a new scene, is only a pose, not a clip. The NLA clip I make has no effect in a new scene..
    The thing is, if you are able to make a workable clip, it does give hope, so I can carry on trying, knowing I'm not flogging a dead horse :)
    Edit : Ten minutes later, got it sorted!
    The reason it made a pose, not an anim clip when I loaded keyframe data is that the two sliders which define the range were locked together under the scrubber slider at keyframe zero. Once I'd found that and moved them apart to define the range, all was well :)
    Thanks for your help!
    Post edited by Roygee on
    edited April 2014
    I used it last on a Daz friendlyt carnegie mellon mocap from cgspeed as those work better in DS
    also iClone BVH exports
    did you use an aniblock by some chance? those act odd at times
    well just tried everyday motions sit drink baked to timeline on genesis
    1992 x 564 - 340K
    Hi Wendy - see the edit to my post above - we were cross-posting.
    What I used was a conversion from the CMU mocaps, made for Poser by mojoDallas and available at ShareCG - just testing and they work really great, after going through DS.
    edited April 2014
    just doing next step also cross posting
    a pose will not remove a clip does and works
    will try your choice next
    1891 x 1013 - 389K
    1891 x 1017 - 485K
    1891 x 1017 - 485K
    I tried one of those you used
    oddly only 12 unzipped dunno if my download corrupt and after schooling the whiners on sharecg got the same spastic moves on genesis!
    (but suspect Poser figures would be fine)
    however
    in spite of a very long series of keyframes it did convert to NLA removing keyframes so not sure what is going wromg for you, sorry
