16 oder 32 BIT in Iray
BigMacBigMac Posts: 97
How can I set 16 or 32 BIT in Iray?
Thanks a lot
  • Richard HaseltineRichard Haseltine Posts: 111,348
    You mean bits per channel in renders? Plain renders ar always 8 bts per channel, you can however use a Beauty Pass Canvas (Advanced tab of render Settings) to save an .exr file in a sub-folder (rendername_Canvasses) which will give a high bit-depth image.
  • BigMacBigMac Posts: 97
    Hello Mr. Haseltine and other DAZ friends,
    Yes, I mean 16 bits per channel. The results of my renderings are all 8 BITs per channel. I work with Mac Pro, maybe I have to do something else, but I don't know what.
    I rendered an image and the result was: Main image was 8 BIT per channel and EXR image was an alpha channel and 32 BITs per channel. I have the graphics card "AMD FirePro D700 6144 MB" and processor "3 GHz 8-Core Intel Xeon E5"
    Thanks a lot
    REZA from Berlin
    800 x 800 - 204K
    Yes, as I said the main render is always 8 bits per channel so you will need to use the .exr and convert it to 16 bits per channel.
    Thank you very much Haseltine,
    it would be very kind if you told me how I can use EXR file to convert to 16 bits per channel.
    I would be very happy if you helped me further.
    Reza from Berlin
    fotocomposing-reza.com
    3ddesign-reza.com
    You would open it in your preferred image editor, make the basic tonal adjustments, and convert it (somethign like Image>Mode>16 bit, perhaps).
