Odd error message with hair prop
I was making 3DL materials for Uchenna G8F and rendering the results with no problems, then I added Short Curls Hair and got this message when I tried to render her again. I have no idea what went wrong once I added the hair prop, but nothing happened. It's referincing something about displacement and sclera and shader baker, which is seems weird for a hair.
I'm using DS 4.9.
350 x 350 - 18K
  • Richard HaseltineRichard Haseltine Posts: 111,430
    Does it clear up if you go to %AppData%/daz 3d/studio4/temp/ and clear the Brickyard folder?
  • mmalbertmmalbert Posts: 412
    I'm in the middle of rendering something else right now but I'll try after it finishes up and report back. Thanks.
    I checked the brickyard folder but it was empty. So I closed DS, rebooted, and tried again. I rendered the hair first on the default G8F, didn't get any error, and then loaded Uchenna again and this time there were no weird errors. So it must've been something I messed up or else the reboot fixed the glitch.
    Again, thanks!
