Dolly Zoom button in the viewport UI
RobinsonRobinson Posts: 751
Dolly zoom button in the viewport UI doesn't "frame" the selected object, it seems to zoom right out away from it.  Have I misconfigured a setting somewhere?
Post edited by Robinson on
  • AbnerKAbnerK Posts: 718
    Mine does does that sometimes with the middle mouse button but the magnifying button works usually. I assume that's the one you're talking about.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    This happens if the object you are framing is far from the origin, especially if you are not looking toward the originI think (it certainly depends on viewing angle, I just can't recall exactly how). If you are using Iray it's not a good idea to have the principal geoemtry far from the centre as rounding errors can produce undesirable artefacts, which isn't to say that the framing issue isn't an issue.
