"Morph Loader Pro" vs "Morph Loader Advanced"
Under the "Figure" dropdown under the "Edit" menu one can access "Morph Loader Pro" and "Morph Loader Advanced"
What, exactly, does it mean to "load a Morph"? What is the difference between the Pro and the Advanced methods?
  • Richard HaseltineRichard Haseltine Posts: 112,099
    A morph is a new shape for an item. To load one you take abse version of the model (no SubD, only one item) and modify it in your tool of choice (being careful not to add or remove anything, just move the existing vertices), then import through Morph Loader (Pro has more options than Advanced) to get a new slider that will move the shape from the base shape (at 0%) to the shape in the OBJ (at 100%).
  • Thank you Richard, for that clear explanation. Do you know why both options (Pro and Advanced) are there?
    Partly, I suspect, historical reasons (they were part of two different, pad for add-ons at one time) and partly as Pro is more complex.
  • That makes sense. Thank you Richard.
