Brekel Proface ... BVH files ... Genesis ... Problems!
jorge dorlandojorge dorlando Posts: 1,159
Hello,
Well, I have a problem here:
genesis using the template that comes with brekel Proface, and creating facial expressions and exporting in bvh format, when I try to import this bvh in Poser Pro 2012 for injects it in Genesis, both do not seem to know (the bvh file and genesis), even using the template (poser maping) genesis that comes along with brekel.
see in the picture below
1920 x 1080 - 311K
  • jorge dorlandojorge dorlando Posts: 1,159
    edited April 2014
    Note:
    I'm using brekel Proface v1.64
    (the same happened in daz)
    the same with M4
    I'm using the templates for genesis/M4 that comes with Proface brekel)
    the compression of the video too, when you save the recording is
    crashing in brekel Proface and he is closing unexpectedly
    it worked fine in previous versions of brekel
    1920 x 1080 - 281K
    Post edited by jorge dorlando on
    PhilC has BVH Helper. It's a python plugin for Poser. I've used it to fix BVH issues in Poser but mainly with movement cycles rather than facial expressions. I don't know how much help the plugin would be. You might want to email Phil at PhilC.net and ask him if he is familiar with the app you are using and if his plugin would be of any use to you.
    Ok,
    I got this help bvh plugin somewhere in my downloads,
    But I also have the Ikinemawebanimate, but here ... my question is that:
    if brekel Proface own a poser mapping file for Genesis, so ...
    the bvh brekel created using the mapping of genesis that comes along when imported in PP2012 and injected into Genesis, should not they already know each other?
    poser in mapping are already in brekel morphs of eyebrows, mouth, etc., and it is producing a bvh then when pp2012 because he does not recognize her mouth and eyebrows genesis?
    as the error might appear:
    "' No Element in the figure to match BVH node Moulth_Upper_C" "?
    Ok,
    As I stated, I'm not familiar with the software you are using. Given the fact that DAZ3D owns Genesis and SMS owns Poser, I think it's more than likely brekel Proface created what they are calling a Poser mapping file. Can you create your own mapping files in this software or are you dependent upon their file?
    Also keep in mind that there is a significant difference between the DAZ Triax rig Genesis uses in DS and the adapted rig Genesis uses in Poser.
    Have to tried customer support for the software?
    yes I've tried tech support, and he answered me quickly, but as he is not a poser User then can not do much.
    Yes, anyone can make a template for your characters poser / daz in Proface brekel.
    But brekel now comes standard with ready-made templates for genesis and M4/v4 among others.
    Now though, the PZ2 file exported from brekel is working in genesis, the poser ...
    bvh's still not working, and not understand why brekel breaks when to compress the avi video. format (though I do not need the video)
