Skin builder 8F and hair/anatomical elements
I wanted to use the pubic hair settings included in Skin builder 8F (https://www.daz3d.com/skin-builder-8-for-genesis-8-females) , but I run into a problem : Settings leave the exact area where the genitals should be uncovered. So if I use a base model without genitals, this lack of genitals becomes obvious. And I can't use the so-called "anatomical elements" or an equivalent since it would cover/replace the area, hence hiding the hair, and Skinbuilder can't be used on them.
So I've no clue how I'm supposed to use these pubic hair settings. Any idea? Thanks in advance.
Post edited by Chohole on
I got same problem. Did you found out how to fix it?
