The Bounty Surface Issue
MJ007MJ007 Posts: 1,718
edited April 2014 in The Commons
I am attempting to load a texture map to the main body of "The Bounty" (http://contentparadise.com/productDetails.aspx?id=1627) it is a FREE model btw... and when I do, the map doesnt appear to take although it does change the body to a solid color and the map doesnt render at all. Ive even tried it on the other 3 surfaces and it doesnt take there either.
And just to specify, the diffuse color is white and it and the strength settings are both set to 100%. So there is no reason it should render dark.
Can someone explain why this happens instead of the map wrapping around the figure?
Im applying a simple spaceship hull texture map that i just googled and downloaded, and nothing works. Ive downloaded several different size maps thinking that might change the rendered results, but to no avail.
Any ideas?
-MJ
Post edited by MJ007 on
  • JaderailJaderail Posts: 0
    The Item would need to be UV mapped to accept a flat image file as a texture properly.
