copy an item
tophandtophand Posts: 139
Hiya!  I kitbashed a prop (created a burning oil drum using a drum and the flames removed from a torch), I need several and unparenting, moving and reparenting each flame and light is a bit of a drag. Can I copy and paste the first completed one?   Hoping this is not dumb question #3,406       BTW-  quarantine?  What quarantine?  I have DAZ. Who needs to go anywhere?
    Exactly ;-)
    You can Create new instances, one or many at once.
  • Instances saves you memory.  You can also save the drum as a scene subset and load it as many times as you need if you wanted to have variations of it.  I find parenting everything to the main prop before saving makes it easier to work with multiples.
  • tophandtophand Posts: 139
    thank you!
