  • Richard HaseltineRichard Haseltine Posts: 112,125
    The items are static - the doors are prts of the corresponding window, and do not move relative to the rest of the piece (though I suspect it would not be too hard to make them move. The whole thing is build of isntances, so as it stands opening one door would open the all (and making each a separate item so it could behave independently would increase the system load). I haven't yet found the swing to know if that is the same.
    Found the swing - it's a sofa-ype of thing suspended from ropes, it isn't set up to swing but could be by positioning a null at the top of the ropes and parenting the swing to that or by using the Joint Editor to move the centre point to the top of the ropes.
  • Ok thanks. Looks great but wanted something I could use in animations and such or just adjust for stills
