How to increase the intensity of Sun Dial?
kar98kdasinikar98kdasini Posts: 56
edited March 2020 in The Commons
[How to increase the intensity of Sun Dial?] I can't find the option.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    DS, using Iray? Sun/Sky is modelled on the real world - if you want a brighter result you would adjust the Tone Mapping settings (or apply effects after rendering).
  • PlantPlant Posts: 127
    Hi i usualy use the enviroment intensity in the render settings
  • Griffin AvidGriffin Avid Posts: 3,884
    Might be overkill for your issue, but I've been using this for working with some HDRIs..
    https://www.daz3d.com/ej-easy-pro-render-suite
  • Sensual ArtSensual Art Posts: 646
    There are several options but depending on your scene, not all may benefit. You may want to post a sample render with your render settings (using sun-sky HDRI or sun node?) so that we can suggest accordingly.
