Luxus export to image output alpha channel doesn't work
iSeeThisiSeeThis Posts: 560
I've tried as it's said in manual. Select File > Export to image > Output Alpha Channel. Go grab png file from temp folder with no luck. No alpha layer as wish. Do I go to the wrong place or missing something else? Thank you!
1442 x 629 - 285K
  • JaderailJaderail Posts: 0
    Have you loaded it into a editor to check? A png will show the BG when viewed but will have a Alpha channel if the BG is just color most of the time. Try to layer it over another image and see.
  • iSeeThisiSeeThis Posts: 560
    Thanks for your reply, Jadrail. But I really must miss something cuz in Photoshop it still has background.
    863 x 912 - 1M
    Umm...what is your lighting setup?
    If you are using an actual background (and a geometric 'world ball' counts) then you can't get a 'background' free png unless your camera 'looks' past the geometry. And then it will only remove the background beyond the geometry.
    It should work with a 'sun/sky' setup or a HDR map with no geometry...
    And did you enable 'premultiply alpha' in the render settings?
    Sir, I used these light set. I did put any background. Just an object alone. But there is always the blue screen (in the aspect frame).
    343 x 344 - 68K
    Then you need to make sure to set Premultiply Alpha to On...
    First image...PMA OFF
    Second...PMA ON
    800 x 1000 - 141K
    800 x 1000 - 780K
