Applying Mesh Smoother
Hello. Daz3D seems to be the undisputed heavy-weight champion of features that are unexplained, yet bog down my system.
Whenever I move a character joint, even a finger, I have to wait for "Applying Mesh Smoother". What is this? A clothing effect? Can I select all nodes in the scene and turn something off in the parameters to stop it? Thank you.
The Smoothign Modifier does two things - it literally smooths the mesh and it can also be set to fix poke-through with oen other model (usually the figure wearing the clothes/hair). It can take a while to process, so when doing the main posing you may want to swtch it off - I do have a script for this https://www.dropbox.com/s/bwgw8ckbk46ysif/ToggleSmoothing.zip?dl=0
That sounds ideal. Thank you, I'll give it a try!
