Weird noise when using Commander Hair
Hi,
I just tried Commander Hair for Genesis 8 (). I like it very much, but I have a weird issue with it. On some darker figure skins you see some noise on the forehead of the figure. See attached pictures. (BTW. Can I somehow put an attached pic into the post?)
If you zoom in very much so you get the details, you see the effect during rendering but it disappears at the end of the rendering. But rendering time increase very much. If zoom out, so that you see about half of the figure (typical portrait), rendering is much quicker but the effect stays until the final render.
If you switch render mode to interactive, the noisy area becomes a dark green surface.
I played around with the material settings but to no avail. Any ideas?
428 x 517 - 321K
237 x 308 - 110K
  • carrie58carrie58 Posts: 4,171
    To put your pics in your post click on your pic -copy the link to the pic , then hit the little cog wheel on the right corner of your post and click edit ,now click on the little pic icon ,and paste the link to your pic, go to wideth and make it 800 . click okay  and save .That looks like the scalp is showing up  hmmm there is some way to fix that but I don't remember it ....
  • It's generally a smoothing modifier error. Adjust the scale of the cap/hair. Should take care of it.
  • Sorry, I missed your comment. That resizing of the hair cap was my first idea, But there is no sizing modifier on that hair.
    edited April 2020
    Tge second inage happens to me if some reason I use the geometry tool at times, did you by any chance use it im your scene?
    Also if there is no modifier, scaling could do the trick.
    Post edited by Paintbox on
