michael 4 and victoria 4.2 in poser 9
greatnpowerfullgreatnpowerfull Posts: 0
searching the net I noticed a lot of free content for Michael 4 an Victoria 4.2 an I just got poser 9 an I purchased both figures from daz.
I cant get them into poser 9.also how to I add the extra clothing ect into poser 9 that's made for those two figures once I get them working?
im using windows 7,64 bit
please help?im new in poser an daz
    Are you installing with DAZ Install Manager, or manually?
  • greatnpowerfullgreatnpowerfull Posts: 0
    tried both
    In Poser, at the top of the Library pane when you're at the top level there should be an icon of a folder with a running man and a plus sign. Click that to add a new runtime, then browse to the location of the new runtime. For DIM the default location on Windows 7 is C:\users\Public\Documents\My DAZ 3D Library\Runtime (I'm not sure if Poser requires the path up to Runtime or just up to My DAZ 3D Library).
    edited April 2014
    I went in my documents an theres a daz3d folder,i put the runtime there it says not a valid runtime folder
    Post edited by greatnpowerfull on
    Did you try both with and without the Runtime at the end of the path?
    I don't see runtime,an what do you mean path?
    What was the name of the file or folder you put in My Documents\DAZ 3D?
    I hit the man with the plus,then it says browse for folder an under my documents is a folder jaz3d if I click ok it wont work it says folder selected is not a runtime folder.theres a make new folder option,should I do that?
    You want the folder where the product is installed. Using DAZ Install Manager, the default location is "C:\Users\Public\Documents\My DAZ 3D Library" for Windows 7, or "C:\Documents and Settings\All Users\My Documents\My DAZ 3D Library" for Windows XP -- note that this is in Public (also called Shared) documents, not in "My Documents" under your own user account. What Operating System do you have?
  • frank0314frank0314 Posts: 15,102
    Click on the file circled above and add in your runtime
    356 x 743 - 33K
    I found both figures,an can now load them into a scene.now if I purchase or download extra content such as clothing for both and I want to turn v4.2 into http://www.most-digital-creations.com/raffaela_victoria_4_genesis.how do I install the extra content and will the rafaella work?an how do I get her to work?
    Content that comes in zips will have a Runtime folder, sometimes as the top-level folder in the zip, sometimes one or two levels down. You need to extract the files from the zip to a temporary location and MERGE just the Runtime folder with the Runtime folder you are using in Poser. Ignore the folders above Runtime from the zip.
    im trying to put hair on Michael but when I click conform to.michael dosent show up.only a cape and supersuit.im making superman.i can canform the clothes but not the hair.help?
  • JaderailJaderail Posts: 0
    edited April 2014
    Somethings are just Textures (or color maps) for other things. They need the item they are made for to be used. For a Hair texture to work you must first have that item as content, have it loaded and then the texture would work to change how that item looked. A texture is not the Hair prop that M4 would have on it, just a new look you could put on the Hair if you had it and was using it.
    Have you read the free DAZ Studio User manuals yet? They would help you I do believe.
    http://www.daz3d.com/forums/discussion/32249/
    Post edited by Jaderail on
    Some hair is not a conforming figure like most clothing, but just a prop that sits on the head. In this case you "Parent" the hair rather than "Conforming" it.
    so just put any Michael hair on an add the texture?also what if skin pokes through the clothes?for instance with the supersuit?
    edited April 2014
    Also there are different types of Hairs, some are just a prop. Once it is loaded it gets Parented to the Head.
    And Mike Beat me.
    As for Poke through in Poser I can not help, I only use Poser to create mat files to use in DS and Poser type items I make for my own use.
    The Supersuit is for Genesis -- are you using it on Genesis or Michael 4?
    m4.it says supersuit for m4
    Is that a Free item from some site? We may not know the item. There is a Supersuit sold by DAZ 3D for genesis with that name.
    yes free.a tiny bit pokes through
    In my old days I would just do Hide of the body part that was poking through if it did not hide parts that was needed in the finished render.
    everythings good but Victoria 4.2 came with no hair an when I try to conform poser hair it dosent fit?
    You have to buy hair that will fit to V4.2. Poser hair isn't made for DAZ figures. You can parent and adjust the scale on the x,y,z to get it close as possible
    ok where do I buy the hair an how do I put it on in poser?also where do I change the axis at?
    edited April 2014
    In the parameters
    This is Jessi hair on V4
    784 x 800 - 796K
    227 x 515 - 77K
    Post edited by Chohole on
    ok,now I just purchased the v4 hair called accents hair,installed it an added it in the scene but it has no color?
    You will find those under poses, as they are mat poses for the different colours.
    edited April 2014
    thanks,also is there a way to flip hair an make the part be on the other side?an when I put a cape on a figure,i conform it but when I change the figures pose the cape dosent look right.what do I do?
    and are there ways to change hair an skin color for a model?like for if im making a hulk green.an what about making skin or clothing
    look torn ?and if I want to put a star on a models chest,a superhero logo is that possible ?
