HELP!! Some D Force Hairs Not Rendering in Iray
I have an issue with AprilYSH Ingrid hair and Side Swept Updo Genesis 8 Female Hair
Both are visible in preview, but are not rendering in IRAY, only getting the scull cap. Is there a plug in I need?
Both of these use a different shader to the other D Force hair props
Anyone else got these issues, or is it just me?
  • felisfelis Posts: 6,502
    When you say render, is it then an actual render or just Iray in the viewport?
  • MsteneMstene Posts: 30
    edited March 2020
    Oddly enough; it does not appear in the iray preview, but when you actually render it does indeed show up.  This makes posing a little bit tricky (you have to rely on texture shaded view to pose).  Then render for real and it will be there  =D
    Post edited by Mstene on
    You can enable preview in the Parameter tab. Just be aware that this will increase ressource load. So unless you have a powerfull pc, it is best to swith to another mode than Iray preview before render.
  • maiku69maiku69 Posts: 5
    In actual render, I can get to see if using preview, but is it right preview should be on to do a proper render?
    PS my pc copes with preview render, just acnnot see why you need invisible hair... ;)
