Surface window texture doesn't display properly
I'm sorry my English is not very good, I loaded after any default, surface texture can't display in the window
865 x 684 - 326K
865 x 684 - 324K
  • felisfelis Posts: 6,603
    You need to click on 'Genesis 3 Male' on the left side to expand and then select one surface. There are multiple surfaces on a character, and therefor you need to select a single surface to see the values for that.
    Hello, thank you for your suggestion, but my problem is not the way, when I open the window surface, can't locate texture characters, shown as a blank, you can watch I upload pictures, I use Windows 10
    865 x 684 - 76K
    865 x 684 - 76K
    Ohhh!!! I'm sorry is I was too stupid, thank you for your advice!!!!!!!!!!!!!!!!!!! thank you
    This problem has been solved, I was too stupit
