Manually Installing Smart Content
KeithHKeithH Posts: 338
Hi -
A few items just do not just up in DIM or there are things showing I own in DIM and having trouble installing.
I installed a few items manually. For the items that support Smart Content, is there a way to make them show up in the Smart Content window?
Thank you
  • HavosHavos Posts: 5,712
    If the support files (the are stored in runtime/support and are the files that end in .dsx), have been manually copied into the right place, then you can right click on the Content Library tab and then select DB Maintenance. This will give you an option to reimport metadata files, and this will give you a list of all your products with smart data. Click the one you installed manually and this should install the Smart Content you are missing.
