Curly Bun hair causing posing paralysis
Hello -
Is there any way to keep Curly Bun hair from killing viewport posing other that deleting it from the scene? Merely turning it off does not seem to help. But I have definitely identified the hair as the issue.
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 110,770
    If you select the hair is there an entry for mesh Smoothing (not Mesh Resolution) in the Parameetrs pane, under General? If so turn it off while posing.
  • RenderPretenderRenderPretender Posts: 1,041
    edited March 2020
    That didn't help. I think that hair model is just too heavy for practical use.
    Post edited by RenderPretender on
  • galiengalien Posts: 150
    In addition to Richard's suggestion (turning off the smoothing on the scalp), try also reducing the value of the "Viewport Line Tessellation Sides" parameter for the hair from 2 to 1.
    Sorry, I hadn't realised this was dForce Hair - yes, reducing the complexity of he model in the Viewport should help.
