Need some help keeping things in OCD level of tidiness!!!!
Hello people :) I'm starting to use this software and although I'm enjoying experimenting with it, I kinda need help and the Tech support have a lot of work so if some one here has any advice it will be very welcomed.
I'm moving all my files into an external drive cause of space and need help in gettin all the folders in propper order and help my OCD ease up, the library folder ended up with data in 3 diferent sub folders and in other 3 sub folders I have the same info and it's all there but some times a window pops up that X file can't be found (and I easily find it in a quick folder search at the same folder where DAZ is supposedly looking)..... basically looks like the room of a messy teenager after a month of quarantine and no parents in sight.... This is mostly cause I had to do some manual installs when sites like renderosity didn't come along with the installer file and I had to go manual.
basically need advice on wich files should go where, if I can merge "my library" with "my daz3d library" do I need a content folder in my library with everything I had in the "my library" folder duplicated?? I'm almost to the point of deleting everything and re install it all over again :S
any el way thanks for any advice.
rob
I refer you to the more knowledgable :- https://www.daz3d.com/forums/discussion/394216/importing-obj-and-losing-path#latest
