camera angle (help)
I see the little view cube in the side
I want to do a front view, but it's at an odd an angel. I just don't like to use it.
http://i67.photobucket.com/albums/h300/Vata_Raven/angle_zps13c187c0.jpg
I want to do this sort of angle, but there is no easy way to get it every time
I want this angel because it shows the body better, so someone could see if the shape & size is good or not
I am not sure what you mean.
To get a Front View, just select the Front camera from the drop down menu. You can still move the image up or down, to get the view you want.
Did you not read what I typed or even click on the image link?
Sorry to interrupt into your communication.
Your English is a bit difficult to understand. :)
What I understood is that you wish to get a front view from the front top, as shown in the image. Is that correct?
I'm just a newbie myself, so...
You can position a camera, and then save it as a pre-set. Then you can just re-load the camera whenever you need it.
Or, you note down the exact Y,X,Z value in the posing tab of the camera. Then you can always change the value to the exact spot by manually entering it.
Personally, I click on the character first. Then, moving the camera is easier, because it is already fixed on the charckter.
Is this the view you WANT, or the view you do NOT want, I cannot understand what you mean.
I guess I could try that
thanks for the suggestion
