Rural Chateau III not lighting properly
Okay, so I recently picked up the Rural Chateau III from Jack Tomalin and the lights don't seem to work. I load the enviroment into the scene, select a lighting mode from the product (for instance late afternoon) and then click on Iray preview and the light is barely noticeble. I try changing the direction of the sun nod that comes with the product. The light direction does not change. I try changing the intensity of the light and nothing changes. I make sure the render settings are set to scene only and still nothing. Anyone know what I'm doing wrong? Or is there something wrong with the product?
Thanks
  • FishtalesFishtales Posts: 6,232
    Have you tried Dome and Scene?
  • felisfelis Posts: 6,502
    The product in itself is 3deligth. If you want to use it for Iray out of the box, you need the Iray add-on.
    According to the product page it has Iray settings.
  • wmiller314wmiller314 Posts: 184
    @Fishtales Thanks. Dome and scene did not work, but sun-sky only did work. You got me thinking in the right direction. Cheers! You're awesome! PS it is Iray as well
