DS menus are confused . . .
See image:  Menus are not in order and I can't find general options;  I think the system was tired and I had to hard boot;  now the menus are scrambled and first, I can't find the edit figure to drop to ground.  Not idea how to fix it.    HELPPPPPPPPPPPP
526 x 167 - 21K
  • takezo_3001takezo_3001 Posts: 2,041
    Go to Window=>workspace=>customize=>Menu tab=>Main Menu bar and then Drag and drop the menu items in the order that you want!
  • You're layout is messed up.
    Try Window>Select Layout.
    Switch to one of the inactive ones, and then swap back to your usual, should correct the issue.
    If it doesn't, F3.
    Brings up the Customize Daz Studio menu. Under the Menus tab, the Main menu bar, will contain the options for those items. You can swap the menus into what ever order you prefer.
    If you're using an unsaved custom layout, you'll have to rebuild it.
  • NorthOf45NorthOf45 Posts: 5,896
    First, try Menu -> Window -> Workspace -> Update and Merge Menus (if it's there)
