Most Digital Creations Title Belt
Hello all!
I've been trying for a week now to get the Championship Belt from Most Digital Creations to work in Daz Pro 4.6+. For some reason, I'll load it and nothing will show up. All the maps seem to be there and the object itself loads into Daz, but nothing shows.
Any thoughts on how to fix this issue??
Thanks in advance!
J
p.s. I've tried loading it directly as an Object as well and adding maps myself to no avail, so I'm not sure what the heck is going on.
  • BejaymacBejaymac Posts: 2,005
    Open the CR2 in a text editor (one with a find & replace function), now do you see the line "actor bone_1:2", it's the :2 (colon2) that's the problem, do a find & replace to delete all of them (117 in total), save it and the file will work now.
    DS doesn't need them and it's easier just to delete them all rather than show you how to add in the missing ones.
  • frank0314frank0314 Posts: 15,102
    edited March 2014
    Yes you have to remove every :1 or :2 from a cr2. Depending on your text editor you can do a search and replace to get rid of them all
    Post edited by frank0314 on
    Frank you should only do that if you know what your doing, there can be several thousand of them in a CR2, and not all of them always have the same number, by just deleting some of them you can actually make things worse for yourself.
    Frank's statement makes perfect sense to me, and as a PA I would think that he does know what he is saying.
