Gallery image size
Just wonder...even though I am uploading a larger size image to my gallery , it's showing as a thubnail size in the Gallery. Any suggestions?
    The Gallery team are a different team,    You will need to contact them through the Gallery Admin  [email protected]
  • thank you!
  • Matt_CastleMatt_Castle Posts: 3,292
    I believe there's a 2 MB upload limit in the gallery. If your file is larger than that, it will get resized to fit; this is particularly notable with PNG images with a lot of detail or noise in them.
  • L'AdairL'Adair Posts: 9,479
    @photogirl, Unless Daz has changed something recently, Matt is correct. The way to upload a larger dimension image is to keep the file size below 2MB. I use Irfanview 64-bit, which includes an option to limit jpeg image sizes. In Irfanview, I set the quality to 100 but limit the file size to 2000KB. Irfanview then calculates the best quality compression while keeping the file under the limit. It saves a lot of time and frustration that way.
  • photogirlphotogirl Posts: 3
    edited March 2020
    thank you all so much, I will check to make sure my size is correct.
    Take care and stay safe.
    Just made sure my file size was under 2 MB...still showing as a thubmnail. This has happened a couple of times to me and the rest of the time it's fine. I'll see how it goes for the next time.
    Thanks again!
    Post edited by photogirl on
    Thanks again!
    I'll take a look, if you give us links to those images that are showing as a thumbnail.
  • L'Adair said:
    I just deleted them, the last one I posted was fine.
  • SevrinSevrin Posts: 6,314
    Why don't they just restrict the images you can upload?   Rendo won't let you upload images larger than 2 MB.
  • Sky HndxSky Hndx Posts: 142
    I can't even find their Upload button.
  • zombietaggerungzombietaggerung Posts: 3,953
    edited November 2021
    1601 x 511 - 101K
    Post edited by zombietaggerung on
