I am STILL having trouble installing Measure Metrics.
Subtropic PixelSubtropic Pixel Posts: 2,403
I am using the most current version of DS which is 4.6.2.118.
I only use DIM, and my version is 1.0.1.115
I keep getting this message (both for 32 bit and 64 bit).
Install Manager cannot find a required path. The installer for "Measure Metrics for DAZ Studio 4.5+ (Win 64-bit) Public Build" requires that the installed path for "DAZ Studio 4.x Public Build (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
This message does a poor job of telling me precisely what I need to do. My current folder settings in DIM appear to be correct, and quite standard:
DAZ Studio 4.5+ (32-bit): .... F:/Program Files (x86)/DAZ 3D/DAZStudio4
DAZ Studio 4.5+ (64-bit): .... F:/Program Files/DAZ 3D/DAZStudio4
As you can see, the only thing changed in my installation paths is my partition letter.
I also have other paths defined for Bryce (ancient 32 bit only), Carrara (32 and 64 bit), and Carrara 8.5 RenderNode (32 and 64 bit), but I don't think these will apply.
Question: Can anybody provide a detailed step-by-step procedure to fix this? Yeah. Like I'm 5 years old, because that message above is very "child-proof". :roll:
  • frank0314frank0314 Posts: 15,100
    Public Build is for the Beta of DAZ Studio
  • Richard HaseltineRichard Haseltine Posts: 111,363
    If you see only the Public Build version of the plug-in, check you haven't hidden the other (or had it hidden for you) by using the Show hidden check box above the files list in the Ready to Download tab.
  • Subtropic PixelSubtropic Pixel Posts: 2,403
    LOL, that's a fine how-do-you-do. It should have said "for beta public build", then I would not have gotten confused.
    I have it for both 32 bit and 64 bit on my desktop and only for 64 bit on my laptop (which is fine, by the way).
    Thanks everybody!
